Author Topic: Radiator removal  (Read 120 times)
Offline Madmax16
  • Bike: DL650 L5
Radiator removal
« on: May 01, 2021, 14:55:03 »
Hello all does anyone have any instructions on how to properly remove the rd from the bike ?
Offline Froglodyte
  • Bike: DL650X L0, BMW R850R
Re: Radiator removal
« Reply #1 on: May 01, 2021, 15:16:34 »
don't know if the Glee is the same but on the gen1:
Drain the rad and remove hoses
Disconnect the temp sensor on side of rad
Remove lower bolt at bottom of rad
Remove both large button head screws which secure the lower fairings ( about halfway up the rad)
Unclip the top electrical connectors on the rad guard ( they just push into the guard so from underneath, squeeze the pins together and they will push out upwards)
The rad now hangs on a rubber bush. Slide the rad sideways and it will drop out.
Hope I've remembered everything!
Offline Madmax16
  • Bike: DL650 L5
« Reply #2 on: May 01, 2021, 16:15:11 »
Thank you buddy
