Hello, I was trying to overhaul my clutch master cylinder but I'm trying to change it to a better one.
The switch seems to be equipped the same, but I wonder if I can't use Low rpm Assistant if I replace it with this. (2019 DL1000XT)
It also has a larger piston size than a genuine product and looks better. I want it even more because the price is reasonable
Please let me know if you've tried it first or if anyone knows. Thank you.
