I removed the hand-guard and dis-connected the cable at the handlebar end,I then removed the sprocket cover and removed the clutch arm from its spline(mine was marked previously so I only noted where it was positioned).This then let me remove the cable from the arm without kinking it.I then used two very small tie wraps to connect the inner cables together, and then carefully pulled and wiggled them through,I only had one glitch, it was when the cable got stuck behind the coil,I had to get it to a position where the two inner cables could be slid out into a better position and it went through OK.It’s quite tight when the new cable top adjuster goes through the bracket just above the radiator, you just need a bit of patience but it just wiggles through.
Two Wheel Centre (Suzuki dealer in Mansfield Woodhouse) called me back this morning, and I ordered a new cable,£48 (ouch),good service, the stores person was very polite and apologised about the price and he was aware that no-one makes an aftermarket cable for the Glee.He will call or message me when the new one arrives from Suzuki and I will can it.
