Author Topic: Fork brace doesn't fit.  (Read 277 times)
Offline Paul_Nicholson
  • Bike: DL650A L5
« on: June 16, 2018, 15:13:09 »
Afternoon,
I purchased a Cosmo fork brace from a fellow member a while back, but it doesn't seem to fit. Having read an article about transporting bikes and how overtightening straps can mess around with your fork alignment and that loosening then tightening back up can sort it out. So I'm feeling brave and thinking about giving it a go.
Is it possible to get at the bottom bolts without taking the entire front fairing off? Haynes seems to say remove the lot...
Online UK_Vstrom650
  • Bike: DL650A L2 White
Re: Fork brace doesn't fit.
« Reply #1 on: June 16, 2018, 16:50:46 »
Yes it is. I've removed my forks three times to refresh fork oil and replaced a leaking seal & have never removed the front fairing.
Is it just it won't fit on, or it won't tighten? It may help to loosen the front axle to allow a bit of movement of the forks?
  • Bike: DL650A L5
« Reply #2 on: June 16, 2018, 18:38:59 »
It won't fit on, it's a couple mm out. How do you get to both bolts without taking the fairing off then, is it just a bit of a fiddle?
Online UK_Vstrom650
« Reply #3 on: June 16, 2018, 20:26:56 »
Small socket wrench will do it. You don't get much space to turn it, however you don't need to turn it too much to slacken it off enough for movement/to remove.
Good luck with it. If you get really stuck, I'm due in Sheffield for work on Monday the 25th so could potentially come and help  :fix:
  • Bike: DL650A L5
« Reply #4 on: June 16, 2018, 20:43:14 »
Cheers, I'll not get the chance to try again until next weekend. I'll let you know!
  • Bike: DL650A L5
« Reply #5 on: June 29, 2018, 07:16:40 »
Success! Loosened the bolts on the forks and managed to get the brace on. Need an excuse to get out and test it now...
Online UK_Vstrom650
« Reply #6 on: June 29, 2018, 07:57:18 »
Result  :fix:
As for the excuse, just look outside  :sunny:
Enjoy and let us know what you think  :auto-dirtbike:
Online ggreen1959
  • Bike: 2005 DL650 K5 V-Strom, 1998 VTR Firestorm, 1977 RD250D
« Reply #7 on: June 29, 2018, 09:20:57 »
What's the general opinion out there about a fork brace? Theory says it must be better and racers use them, but I haven't ever fitted one aftermarket. Theory also says it will increase the unsprung weight and therefore make your suspension work that little bit harder!  :shrug:
  • Bike: Burgman 650 6550 mls: SV650 00 mls : 1200 Harley Sportster 11800 mls
« Reply #8 on: June 29, 2018, 09:30:22 »
The percentage increase in unsprung weight must be negligible.
I fitted a Cosmo brace to a K9 and the difference / improvement was noticeable.
Look at the clock and the calendar.
It'll never be now again.
So just get out and do it.
As fast as you possibly can.
Online Graham62
  • Bike: DL650 K6 Blue
« Reply #9 on: June 29, 2018, 10:14:48 »
I've got one on my k6 Wee and it handles a lot better.  :thumb:
Graham
Online ggreen1959
« Reply #10 on: June 29, 2018, 10:28:35 »
Maybe an upgrade for me then!
Online Graham62
« Reply #11 on: June 29, 2018, 12:46:42 »
 :thumb:
Graham
Offline DLste
  • Bike: SV650
« Reply #12 on: June 29, 2018, 13:54:53 »
@Paul glad you got it on you will feel the difference. :fix: :thumb:
V-Twins Just Love um :)
"I DON'T RIDE A BIKE TO ADD DAYS TO MY LIFE.
I RIDE A BIKE TO ADD LIFE TO MY DAYS"
Offline hotbulb
  • Bike: 2014 Glee
« Reply #13 on: June 29, 2018, 18:12:06 »
I certainly noticed the improvement when I fitted a Cosmo to the Glee.
