Author Topic: disc lock recommendations anyone?  (Read 388 times)
Offline Jack Meoff
  • Bike: 2015 Dl1000 Adventure
« on: June 09, 2018, 10:10:05 »
As per the title, up to around 50 quid I reckon. Already got a thatchem alarm and decent chain so this is just another deterrent.
Offline Paul_Nicholson
  • Bike: DL650A L5
Re: disc lock recommendations anyone?
« Reply #1 on: June 09, 2018, 11:07:39 »
I got a motrax vishas one free with a mag subscription? It's pretty decent.
Scratch that,  it's been discontinued
Offline TLPower
  • TLFuelstop
  • Bike: The Nail (Cagiva Navigator) Darwin (KTM 1190 ADV)
Kick your tyres, light your fires and the last one off 's a cissy....
Captain Eric "Winkle" Brown.
Online tallpaul
« Reply #3 on: June 09, 2018, 16:19:07 »
I have a mammoth one... :shock:
Lock, that is.
Offline Freddyfruitbat
  • Bike: V-Strom DL650 AL2; BMW R1200RS Sport SE
« Reply #4 on: June 09, 2018, 16:54:34 »
Xena XX15 here.  It's been 100% successful for me in that I've never had my bike nicked with it on!  :icon_wink:  Bought it about 18 months ago; I think it came well-recommended at the time. Might be a bit above your price range though?
KC100->CB100N->CB250RS--------->DL650AL2 + R1200RS
Offline King Orry
  • Bike: 2013 Glee A3
« Reply #5 on: June 09, 2018, 17:23:49 »
don't know too much about the locks, except, I had one of those Oxford mini U-lock types, but when the tw@t burgled my garage he managed to smash it off with my sledgehammer pretty easily (note to self.. don’t leave sledgehammers lying around).
One thing I would add is make sure you attach one of those reminder leash things to it, otherwise you will most likely try to ride off with it in place and fall on your @r$€..
(You could use a bungee strap)
Nemo me impune lacessit
MZ Simson 50, Honda H100A, CB250RSA, DT175MX (x5!),RD400E, GP100, MTX125, CB400N, GSX750ES-D, FZ750 (24,000m in 12 months.!) SB200, GPz550 Unitrack, VFR750FJ & FL, ER5, VF1000F2 Bol D'or, SV650, CG125(x2), FZS600, Glee.
  • Bike: DL650A L5
« Reply #6 on: June 09, 2018, 18:17:37 »
Yeah definitely get a reminder cable. I reversed my old bike out and smashed the mudguard, could've been worse but still.
« Reply #7 on: June 09, 2018, 21:17:37 »
Oxford locks have a really bad rep; made of cheese or something.   Wouldn't touch one with a bargepole.
I don't use a reminder cable, because I use my disk lock on the rear wheel, and there are apparently no springy cables available which are long enough to reach the handlebar.  Why do I put the lock on the back wheel?   Ask yourself how easy it would be for two blokes to lift up the locked front of your bike by its handlebars, and wheel it into a van.   Now picture the same scenario with the rear end of the bike locked - not impossible to lift but it's a whole different ballgame and a bit of a no-brainer to lock the back wheel as far as I'm concerned.  Both wheels even better obviously.
A far better solution to the reminder problem (which believe me, would definitely be a problem for me!) is a  tip I picked up I think on this forum but maybe another one: I keep a short length of rubber tubing pushed over the end of the disklock key, which I have to remove in order to close the lock.  I then shove the tube over the blade of my bike's ignition key instead.   Then when I come back to the bike later, it's impossible to insert the key into the ignition until I've taken the reverse steps to unlock the back wheel.   Never failed me yet!
  • Bike: Burgman 650 6550 mls: SV650 00 mls : 1200 Harley Sportster 11800 mls
« Reply #8 on: June 09, 2018, 22:05:46 »
FFB+1 for rear wheel disc lock. I wrap the reminder over the saddle and onto the gear lever or brake lever depending on which side the disc is located.
Look at the clock and the calendar.
It'll never be now again.
So just get out and do it.
As fast as you possibly can.
Offline Loz
  • Bike: DL1000 & Beta300rr
« Reply #9 on: June 10, 2018, 08:36:07 »
Nowadays the scum bags cut through the actual disc, so probably better buying 3 or 4 cheaper/medium priced ones as opposed to one dear one, as it be harder for them to nick.
Offline SimonW
« Reply #10 on: June 10, 2018, 08:45:11 »
I use an Oxford Omega (c£40) but no idea if it's any good. Bought at Motorcycle Live years ago (for about £15). Thatcham approved. I always fit it on the nearside disk (with the handlebars turned to the nearside) to make it hard to access by B. Burglar. Unfortunately, I declared it to my insurance company, so they insist it's used all the time or they halve the payment or something like that.
« Reply #11 on: June 10, 2018, 11:13:04 »
Yeah I found out about that too, fortunately not that hard way - at renewal I realised that declaring my disklock made no more than a few quid different to the premium (no, I don't live in central London!) so although basically I do always use my lock, I really didn't like the stress of knowing that I always had to do so come what may, and it wasn't worth the aggro.   It's a similar story with the whole 'keeping it in a locked garage (at night)'; what about getting the bike nicked off the drive while it's drying off after a wash?  An argument with the insurers will ensue, to say the least.   Definitely worth considering the difference in premium by deliberately not declaring this stuff!
Online tallpaul
« Reply #12 on: June 10, 2018, 16:27:57 »
I never declare any security devices, even though I use them.
Offline Jack Meoff
« Reply #13 on: June 11, 2018, 21:00:18 »
thanks for all the replies.
Online mr_diver
  • Bike: 'onda Varadero Xl1000v9, Yam TTR250 '04, Yam XJ600n '96, GSX14 '06, DL650 K6 (Blue) R.I.P,
« Reply #14 on: June 11, 2018, 23:38:06 »
I'm with TallPaul.
I never declare any thing other than the HISS on the Vara and Suzuki Imobiliser on the GSX.
Everything is locked and bolted to the floor and each other and disk locks. (Apart from the XJ600n as I don't care and they can take that one and leave the rest)
But just in case I forget once and it gets nicked. Those slimey insurance companies will use it to get out of a claim.
So as far as they are concerned my bikes are in a locked garage with no other security.
  • Bike: DL650A L2 White
« Reply #15 on: June 12, 2018, 09:25:40 »
+1 I don't want to be forced to use my disc lock if I park at Squires Café or when popping in to pay for petrol etc.
I have a Krall disc lock which is pretty easy to use and fits nicely under the seat of the Glee.
Offline revapi
« Reply #16 on: June 15, 2018, 19:02:27 »
I use an alarmed disc lock , its just a bit of added security knowing its going to make a noise if moved
Offline S2Rgar
  • Bike: 2015 Glee Red - 2017 Triumph Tiger 800 XRT Red
« Reply #17 on: June 17, 2018, 11:43:36 »
The Oxford Quartz disc lock is on offer at the moment from M&P.
Very heavy duty lock for not a lot of money.
Offline mrp192
  • Bike: 2015 Suzuki DL650AL5 VStrom
« Reply #18 on: June 17, 2018, 22:34:29 »
Saw this cheap padlock with alarm in our local ‘bargains’ store today but think Rolson widely available. Wouldn’t use as sole security but for the price may be worth thinking about as additional security to make a noise when the little B’s wouldn’t Be expecting it.
« Reply #19 on: June 23, 2018, 07:47:45 »
Anyone use an Oxford boss alarm disc lock? Want to know will it fit OK (14 Veek ) and would you recommend.  My bike will have to live outside the next month r so but it will be in the garden outside the window.. Just thought the alarm would help.
