Author Topic: Chain maitenance for a chain virgin!  (Read 1245 times)
Offline jmee54
  • Bike: DL650 L7, Guzzi 73 Eldorado, 71 Ambasador, 79 Convert
« on: September 01, 2017, 19:55:13 »
Guzzis have been my thing for years (still have 3) and before that it was Harleys and Buells (nice clean belt). Before that it was chains, but I'm sure I used and abused them.
What is the general consensus regarding looking after one of these evil, dirty and expensive to care for pieces of outdated drivetrain?
Offline Rich:-)
Re: Chain maitenance for a chain virgin!
« Reply #1 on: September 01, 2017, 20:13:40 »
Well.. your particular piece of outdated drive train is an O-ring sealed chain (or maybe Xring), so doesn't want for nearly as much attention as older standard chains did. It will also last a long time, maybe 20k miles, and won't need a grease repack like a shaft drive will.
There are many views on whether you should clean the chain or not.
Some say don't... I say it depends on what sort of dirt is on it.
I lube with either chain spray (grease) or gearbox oil. I don't use the chain waxes.
I brush the gearbox oil on it, or deliver it via a chain oiler I made.
I clean in several ways, sometimes by brushing on used engine oil then toweling off afterwards, sometimes I spray on WD40 and then towel off. I have used paraffin and even diesel to remove the old used up oil/grease before applying fresh lube.
Do not use water and detergent to clean the chain.
Do not pressure wash the chain.
Rule of thumb is 500 miles between clean and lube, and just lube in between as needed.
Chain oilers are great, especially if you do high mileage or are touring. No need to buy an expensive one, you can make one yourself for very little money that work just as well.
Manual lubing (and cleaning) depends on what conditions you ride in, in time you'll just get the feel for when it wants for something, be it a little oil or maybe a clean.
Online UK_Vstrom650
  • Bike: DL650A L2 White
« Reply #2 on: September 01, 2017, 20:43:10 »
Just to add I rarely cleaned (if ever) my OEM chain. Just ran an oiler & brushed on oil every so often. Use the bike more or less 365 days a year and the chain lasted around 25,000 miles. In fact it only got changed as I needed a new front sprocket, so changed the lot.
Offline Moo
  • Bike: DL650 Glee 2012, Yamaha TTR 250 Raid 1994, TTR 250 2005
« Reply #3 on: September 01, 2017, 22:43:04 »
I wouldn't use waxes as they eventually build up and make a mess which id hard to clean off.
I regularly lube mine using a toothbrush/paint brush and use either gearbox oil, or even better chainsaw oil, as this is actually created to be anti-fling and sticky... Its used on whirring chainsaws!
They can both be bought very cheap (cheaper and longer lasting than cans of lube) and the chainsaw oil leaves by chain looking clean, not rusty as its protected in oil and very well lubed!
Online Ianmc
  • Bike: DL650 K9
« Reply #4 on: September 02, 2017, 08:53:00 »
Just fit a Loobman chain oiler,cheap as chips,and no electrics or vacuum pipes to give you any grief.
Offline Stonec0ld
  • I was Paul_Nicholson
  • Bike: DL650A L5
« Reply #5 on: September 02, 2017, 09:57:56 »
Ooh I didn't realise the loobman was so simple and cheap. I assumed it was like the scottoiler I.e. Expensive and fiddly. I might just give one a go.
Offline Moo
« Reply #6 on: September 02, 2017, 10:23:25 »
Another to look at is a Tutoro Automatic.
Not connected to anything, uses a small weighted pump which jiggles around when riding along to pump the oil out.
Offline Stonec0ld
  • Bike: DL650A L5
« Reply #7 on: September 02, 2017, 10:27:52 »
That's still bloody expensive though!
Online Asmith61
  • Bike: DL1000 K7 - 2011 b-king 1999 1200 bandit
« Reply #8 on: September 02, 2017, 15:48:58 »
I have always used chain wax but just had a look on the loobman site and read all about it and iam about to order one  :thumb:
  • Bike: DL650 AL2
« Reply #9 on: September 02, 2017, 19:42:00 »
I use a PD oiler (mini) and have had it fitted from 200 miles. Now on 25,000 and my local independent refused to take any money off me for a new chain and sprockets when I took it in last week! He said it'll be fine for another 3/4,000 (but keep an eye on it). Either oiled manually on a regular basis or with an auto system should keep them in a good condition.
Offline jmee54
« Reply #10 on: September 02, 2017, 20:05:06 »
Like that Lubeman and the price. Do I need to remove the white wax before I use an oil for lubrication. I'm going to order one now, thanks for the heads up!
Online Rusty Nuts
  • Bike: DL650 L2 White
« Reply #11 on: September 02, 2017, 20:28:41 »
I would wash it with paraffin if it is gunged up with spray wax.
Offline pr
  • Bike: DL650A K7
« Reply #12 on: September 03, 2017, 09:25:50 »
If you use a Loobman, doesn't it get very messy with engine oil flinging around?
Offline frez
« Reply #13 on: September 03, 2017, 10:18:47 »
Auto chain oilers are only worth the money if you are very adverse to maintenance or do a lot of miles, especially a lot of miles in winter. I ran one on my wee as I was riding over 25k miles a year in all weathers and the PD Oiler was half the price it is today.
I didn't need one on my shaft drive S10, but I'm not fitting one to my KTM 1290 SAS as I am now working locally and whilst I'm riding in all weather I'm now down to 6000 miles a year and 30 minutes spent every 2 or 3 weeks wiping the chain down and spraying with some Motul C3 whilst I top up the tyres and check the chain for wear is perfectly acceptable.
Offline Angustoyou
  • Bike: 2013 Glee
« Reply #14 on: October 23, 2017, 18:26:10 »
Having a centre stand makes manual lubing easy, pia without one.
