Author Topic: K&N Oil Filter Failure  (Read 1383 times)
Offline Lincsman
  • Bike: 1995 Triumph Thunderbird 900, 2016 650 V Strom
« on: May 18, 2017, 11:27:51 »
I'm on another forum and this bloke has had a major oil filter failure, and the bikes engine is 75% damaged. K&N aren't interested by all accounts. To add insult to injury it seems that K&N have known about this problem for years. You might want to give it some thought about buying these for your bike in the future.
Unless it's got two wheels and an engine slung in the middle, I'm not interested.
Join The Motorcycle Action Group today at the link below. Protect your right to ride. Do You Care ??
http://www.mag-uk.org/
Re: K&N Oil Filter Failure
« Reply #1 on: May 18, 2017, 15:42:04 »
I was hard pressed to find any critical reviews of the KN-138 K&N filter for V-Stroms. What I have found is a problem with counterfeiting oil filters. Another cause of difficulty is using the nut to installed the filter which can cause problems if too much force is used. It should be put on by hand with the nut used only for removal. For sure do not use the two turns after gasket contact as specified in the Suzuki manual. That's only for Suzuki filters. The K&N should go on hand tight.
See reviews at https://www.amazon.com/KN-138-Powersports-High-Performance-Filter/dp/B000E2CVDI/ref=sr_1_1?ie=UTF8&qid=1495118341&sr=8-1&keywords=kn+138#customerReviews
Offline Rich:-)
« Reply #2 on: May 18, 2017, 16:09:57 »
I use Hiflo oil filters on all of my bikes, past & present.
Never had an issue.
The weld on nut is an issue for many filter types. Bosch filters for some vehicles had a similar issue once where the welding had perforated the filter case and they leaked from new.
Definitely good advice there greywolf - don't use the nut (if you can avoid it) until you are ready to bin the filter. Better still, buy filters that don't have the nut, hand tighten and use a filter wrench to remove it.
That way you avoid having the weak point in the first place.
« Reply #3 on: May 18, 2017, 16:33:10 »
The K&N KN-138 filter is a HiFlo HF-138, recommended by John Weldon, with a nut welded on.
Offline Rich:-)
« Reply #4 on: May 18, 2017, 17:57:43 »
Oh bugger.... so I need to change oil filter brands then... :shock:
Offline superteso
  • Bike: K1300GT my2010, V-Strom 1000 my2014
« Reply #5 on: May 18, 2017, 18:21:34 »
But the original filters make you crap?  :shy:
si stava meglio quando si stava peggio
Offline Rich:-)
« Reply #6 on: May 18, 2017, 18:26:37 »
Oh, I get what you're saying. The HF138 doesn't have the nut so is better/OK to use.  :grin:
Yeh, looks like the filter material might be different too as it seems to be a different colour.
Offline Flanners
  • Bike: Vee GT K7, Ducati 916 SPS, MV Agusta F4
« Reply #7 on: May 18, 2017, 18:56:19 »
Not withstanding fakes. I can see this problem more as operator error, I agree with above posts only use the nut on removal, have had them on my Ducati and like all other filters I have had they have been fit and forget until the next year, choose K&N when access is an issue this is no problem on the VStrom so I use Hello-Flo.
Offline Sasquatch
  • Bike: DL650GT K9
« Reply #8 on: May 18, 2017, 21:56:17 »
Hole in the nut is too small to get paint trough it, and welding is done on bare steel => can under the nut is uncoated and corrodes in no time. Faulty by design, counterfeit filters without hole in the nut would probably last longer.
Offline Robotstar5
  • Bike: DL650K5 LT-F250
« Reply #9 on: May 23, 2017, 21:53:25 »
I've been using K&N oil and air filters for 30 odd years without any problems.
Offline Lincsman
« Reply #10 on: June 07, 2017, 12:11:09 »
This chap on another forum who had the problem with the K&N filter, had the bike fixed at a cost to K&N of 2500, nice to see a company admitting that it got it wrong.
