Author Topic: Compatible exhaust with Givi panniers  (Read 1517 times)
Offline madasadad
« on: July 12, 2016, 09:40:44 »
I'm looking a new exhaust that is compatible with the Givi pannier frames and bolts straight on without the need for any ecu adjustments.  Any thoughts?
2013 650, full Trekker luggage, Givi Airflow, heated grips, scottoiler, hyperpro Spring
Offline Sam
Re: Compatible exhaust with Givi panniers
« Reply #1 on: July 12, 2016, 11:43:57 »
The Fuel exhaust will fit with Givi racks without any problems.
Edit: I fitted the round one without any problems, not sure about the oval version!
  • Bike: DL650A L2 White
« Reply #2 on: July 12, 2016, 19:08:43 »
If you have, or intend to fit a centre stand this will also limit the exhaust you can fit. I think Scorpion may fit.
Offline alibx11
  • Bike: 2012 V Strom 650 al2
« Reply #3 on: July 12, 2016, 19:57:41 »
Hello Mad,
I fitted the Scorpion Titanium 3/4 system onto mine about 6 weeks ago but found the exhaust didn't quite clear the pannier rack.
I just welded another lug onto the frame an inch lower on the right frame.
If you want to see or hear it give me a shout next time your down Bangor way and I'll show you.
Offline madasadad
« Reply #4 on: July 12, 2016, 20:51:10 »
Yes I have the centre stand, didn't realise that could limit my choices!
Offline alibx11
« Reply #5 on: July 12, 2016, 23:24:50 »
Centre stand will not make any difference to you. Don't worry about it.
The stop for the stand is on the left so doesn't affect the exhaust as it comes up the right side of bike.
« Reply #6 on: July 12, 2016, 23:35:49 »
For example,  Arrow exhausts don't fit with centre stands http://www.arrow.it/en/assembled/1210  I think it's to do with the way the pipe bends...? I seem to recall seeing a few others that say they don't fit with one as well, and some saying they don't fit with panniers. Worth checking before you order.
Offline ms666
  • Bike: DL650 XT
« Reply #7 on: March 17, 2017, 14:34:03 »
GPR can fits with givi frames and central stand
Offline BlackRockFox
  • Bike: DL650A L3 "The Blue Pearl"
« Reply #8 on: March 17, 2017, 18:54:45 »
Unnecessary quote removed
+1
*NOTE* I bought the frames second hand and they had been modded to fit closer to the bike and still there are no problems
Have a centre stand as well (OEM)
Exhaust is brilliant in traffic as well, people know you are there without being deafening
Very pleased with whole set up
