Author Topic: What have you done with your bike today?  (Read 29781 times)
Offline Ridaz
  • Bike: Africa Twin 2017
« Reply #360 on: October 14, 2017, 20:52:13 »
Fitted my mirror extenders.... stripped my Astra down..... well I'm sure you read all this up there^^ Thanks for all the help TLP
More importantly....
I had a ride on the nail...Now I understand why it is so difficult to stay close to it when it is ridden hard on the twisties, it really does make TLPower look like a good rider. Quite a change from the Glee and Nelson. Maybe we need to fit some smaller wheels to the AT ;)
Great day, fantastic cake and of course cracking company.
  • Bike: DL650 L2 White
« Reply #361 on: October 14, 2017, 21:59:22 »
Hmmmm, the Africa Twin Supermotard. What with Ridaz' bike and TLP's garage full o' wheels......
Offline TLPower
  • TLFuelstop
  • Bike: The Nail (Cagiva Navigator) Darwin (KTM 1190 ADV)
« Reply #362 on: October 15, 2017, 07:01:34 »
I'm up for it.
The later CBF wheels would be ideal as they come with ABS rings.http://www.ebay.co.uk/itm/Honda-CBF600-REAR-WHEEL-NEW-DISC-SPROCKET-AND-TYRE
Kick your tyres, light your fires and the last one off 's a cissy....
Captain Eric "Winkle" Brown.
  • Bike: DL650A L6 & CRF1000L Africa Twin
« Reply #363 on: December 28, 2017, 15:31:48 »
Fitted a GPR can to the Africa Twin  :fix:
** Biker Friendly Campsite in West Wales **
There's a big difference between knowing your shit and knowing you're shit
I will NEVER use JT's Motorcycles of Swansea! http://www.v-strom.co.uk/smf/index.php?topic=2717.msg205443#msg2054
Offline TLPower
  • TLFuelstop
« Reply #364 on: December 28, 2017, 15:43:29 »
Magnificent.
Also a kind thing to share the beautiful noise with others. :)
« Reply #365 on: December 28, 2017, 15:55:16 »
I did record the vroom vroom noises but it doesn't sound as good in the clip as it does in the flesh  :shrug:
Offline Ridaz
« Reply #366 on: December 28, 2017, 20:37:49 »
OK, we need a trip over to listen in person :D
Not sure if you have seen these yet :grin:
https://www.amazon.co.uk/Honda-CRF1000L-AFRICA-BLACK-CRASH/dp/B01N5FRANF
^Oh dear, I'm now banned  :icon_wink:
« Reply #367 on: December 28, 2017, 22:20:26 »
I would sooner have my bollocks removed.
  • Bike: 'onda Varadero Xl1000v9, Yam TTR250 '04, Yam XJ600n '96, GSX14 '06, DL650 K6 (Blue) R.I.P,
« Reply #368 on: December 28, 2017, 22:40:01 »
They also do one for the africa twin that fits without crash bars if anyone needs one.
I was thinking of getting one for the Varadero as a joke, then I saw the price and realised the only joke was the person buying them  :crazy:
Offline Paul_Nicholson
  • Bike: DL650A L5
« Reply #369 on: December 29, 2017, 14:11:43 »
Why???
Offline DLste
  • Bike: SV650
« Reply #370 on: January 06, 2018, 21:02:01 »
Give her a good wash down looks new again. :thumb:
V-Twins Just Love um :)
Offline pichulec
  • Bike: Kawasaki KLV1000 (DL1000 K5)
« Reply #371 on: January 06, 2018, 21:07:33 »
Fitted modified clutch basket from sharealike. Bike much better now, almost no vibe :)
KLV1000 - my pride and joy
« Reply #372 on: January 13, 2018, 22:57:38 »
My days off in the last few weeks have been fairly busy.
XJ600n:
Fixed a corroded and crumbling connector on the main control relay.
Sorted a leaking exhaust to head gasket.
Cleaned and greased calipers.
Oil change.
And a light scrubbing.
Fitted LED H4 headlight bulb.
TTR250:
Re-routed exhaust end can parts (fouling rear wheel)
Fitted legal licence plate for MOT
Found and fixed oil leak spraying onto exhaust.
Removed seized pillion pegs (had to snap LHS peg)
Fitted new Oxford Commuter heated grips.
Varadero:
Fitted Oxford heated grips
Replaced Givi plastic M5 top plate with old style all metal tube M11 version.
Fitted LED H4 headlight bulbs.
GSX:
Checked tyre pressures
Rotated the wheels
Started it (first time since October - still sounds angry)
Next week I need to replace the secondary master cylinder piston and rod on the Varadero.
It's been an issue for a while, cost me a disk last summer and it's starting again.
Cleaned it in the summer it's getting replaced this time. Apparently it's a common fault on bikes like the VFR800, ST1300, Goldwing and Varadero that use the this type of combined braking system.
Some day soon I may get a day to go out and fecking ride.  :bawl:
Offline TLPower
  • TLFuelstop
« Reply #373 on: January 14, 2018, 04:54:17 »
Busy boy. :thumb:
Offline DLste
  • Bike: SV650
« Reply #374 on: January 14, 2018, 17:46:20 »
Take front & rear wheels off clean and ACF50 Both, Clean all calipers take belly pan off clean front down pipe, ACF Front end.  :fix:
Clean chain and lube, then tuck her up as we are expecting heavy snow this week. :bawl: :groan:
« Reply #375 on: January 20, 2018, 19:33:03 »
Replaced the Secondary Master Cylinder internals on the Varadero. Should now see the end of my rear brake dragging issues.
Also cleaned and bled the whole system.
Changed the front wheel bearings in the XJ600n.
Tomorrow I'm having a day off and going riding...
On the Mrs' GSX.   :auto-dirtbike:
« Reply #376 on: February 16, 2018, 21:12:07 »
Said goodbye to the XV125. The new owner picked it up tonight.  :slap_my_arse_hippo:
Old enough to know better, but too young to care...
« Reply #377 on: February 18, 2018, 17:36:01 »
Bit of time spent in the garage again.
Managed to remove 2 exhaust header bolts on the Divy for sort the leaking gaskets, then adjusted the chain.
The TTR250 had a little more serious open engine surgery.
The RHS cover gasket has been leaking and spitting oil onto the hot exhaust and onto my leg.
All went as expected apart from the old gasket was well and truly stuck on the outer cover. Took a while to clean it off.
Offline Mr Nick
  • Bike: 1979 Suzuki TS185ER, 1979 Moto Guzzi V50, 2010 KTM 990 Adv
« Reply #378 on: February 24, 2018, 16:15:59 »
Bought another one.....
I'd put feelers out that I was looking for a wee project to fill the evenings and I got a bite today.
I'm now partially back in the fold again as it's a 2001 SS650SK1 in blue: a little scruffy around the cases and the fork sliders could do with a re-paint, but 22k miles, 2 owners with Scottoiler, fancy levers and Evo can. It just needs tidying and time: not seeing much that needs bought so this shouldn't be another nut & bolt resto job.
Offline Mr Nick
« Reply #379 on: February 25, 2018, 18:05:13 »
Started on the SV today: good power wash to begin with & on to the ramp.
So far the seat unit, tank and airbox are off - back to it to take plenty pics before I do much more.
Next job is to sort out some way of getting it on axle stands as there's no centre stand.
