Engine RPM @ 60 & 70 MPH
Topic: Engine RPM @ 60 & 70 MPH (Read 1891 times)
krisv
Bike: DL650 K5
July 09, 2013, 15:29:04 »
Hi,
Can anybody tell me what the engine rpm is under the following conditions for a K4/K5/K6 Wee?
60 MPH Indicated on Speedo
70 MPH Indicated on Speedo
6th Gear
Assuming Standard Sprockets
Cheers,
Kris
frez
Re: Engine RPM @ 60 & 70 MPH
July 09, 2013, 15:36:58 »
Well 5k revs is an indicated 68mph, you can work it out from there. However, 68mph on the speedo is not 68 mph on the road, probably around 62 or 63mph.
greywolf
July 09, 2013, 16:20:46 »
You can check any numbers you want at
http://www.gearingcommander.com/
and even do sprocket changes. Just be aware the numbers are based on the stock instrumentation so indicated speeds are shown whereas actual speeds will be about 8% lower.
bat-kam
July 09, 2013, 19:04:30 »
Greywolf,
That is very good website
Thanks
Suzuki all the way: '98 Bandit > '99 GSX600F > '09 V Strom DL650 > '09 SV650S > '10 V Strom DL650 > '04 GSX-R 600
krisv
Bike: DL650 K5
July 09, 2013, 20:09:41 »
Excellent site Greywolf... Exactly what I needed.
