Tyres
Engine management light come on after puncture
Topic: Engine management light come on after puncture (Read 2259 times)
Colin sharp
Bike: Suzuki xt 1000
February 22, 2018, 19:31:48 »
Hello there can anyone help had a puncture today took it to be fixed which they did .but on way home engine management light came on .but bike feels OK . So the only thing is rear wheel been off .how can I turn it off .cheers colin
SuzukiSte
Re: Engine management light come on after puncture
February 22, 2018, 19:36:17 »
Are you sure its not the ABS Light if the wheel as been off.
Colin sharp
February 22, 2018, 20:19:23 »
No mate definitely engine management light
greywolf
February 22, 2018, 20:52:13 »
Are you seeing a check engine symbol or an FI light/symbol? What model year or build month/year, not registration year, is the bike?
kwackboy
Bike: BMW F800GS Adventure, Honda CB500s
February 22, 2018, 20:53:42 »
Does your XT have tyre pressure sensors or traction control .? It's possible either the rear abs ring might have been damaged/distorted or the pressure sensors (if you have them) may have also been damaged.
Other than that you can use the diagnostic plug to bring a fault code up which will give you the answer.
paulja
Bike: DL1000XT L8
Reply #5 on:
March 02, 2018, 22:25:32 »
It can only be the ABS\ Tracation control, so maybe pull the ABS fuse, turn the bike on, then off, then put the fuse back in and see if it resets. Failing that you'll need to get the bike into 'Dealer Mode' to read the actual error code.
Tyres
