Massive thanks to Kwackboy AGAIN for the sterling service, Suzy has a new regulator and battery and is charging properly.
After fitting the regulator it still wasn't charging properly with the extras so a new battery was put on and works great.... I have discovered one thing though, I must get rid of my front halogen spotlights as they are seriously affecting the charge of the battery.
luckily I already have some front LEDs ready to fit after I build my LED rear cluster assembly (nothing too technical I can assure you)
Thanks again Brian you always go the extra mile
