Author Topic: Suzy is all better now  (Read 1181 times)
Offline Holmsey
  • Bike: DL650 L9
« on: March 15, 2018, 18:29:41 »
Massive thanks to Kwackboy AGAIN for the sterling service, Suzy has a new regulator and battery and is charging properly.
After fitting the regulator it still wasn't charging properly with the extras so a new battery was put on and works great.... I have discovered one thing though, I must get rid of my front halogen spotlights as they are seriously affecting the charge of the battery.
luckily I already have some front LEDs ready to fit after I build my LED rear cluster assembly (nothing too technical I can assure you)
Thanks again Brian you always go the extra mile  :thumb:
IBA Member
RBLR 1000 - 2018 -2019
Armistice 1000 - 2018
Re: Suzy is all better now
« Reply #1 on: March 15, 2018, 18:38:05 »
Was a pleasure,  LED is the way to saving lekky ..  :thumb:
« Reply #2 on: March 15, 2018, 18:48:30 »
LED...it's the future!  :thumb:
Offline Dark-Strom
  • Bike: 2018 Ninja 650
« Reply #3 on: March 15, 2018, 18:56:00 »
Glad your strom is back to full health :thumb:
May your God go with you...
(Dave Allen)
« Reply #4 on: March 15, 2018, 19:31:37 »
Until a problem arises then it costs alot more than just a bulb change ..  :smirk:
Offline Rich:-)
« Reply #5 on: March 16, 2018, 09:21:25 »
So what was the problem then?
Was it the rec/reg or was it just a case of running too many accessories (halogen accessory lights) that were preventing the battery from charging.
Offline Holmsey
  • Bike: DL650 L9
« Reply #6 on: March 16, 2018, 09:26:43 »
The regulator was the problem which also probably affected the battery ....
I didn't realise how much the spotlights were draining the system.
IBA Member
