If you want the right answer to your question then it is best to add the bike model and year into your profile
V-Strom specific discussion
Waterpump Paint?
Topic: Waterpump Paint? (Read 1571 times)
Firestorm
Waterpump Paint?
January 13, 2018, 15:44:24 »
Has anyone managed to match the colour on the Wee engine cases. I want to touch up the waterpump housing and don't want to take it off. Ta!
Rusty Nuts
Manufacturer of iron oxide
Bike: KTM 1090 in orange, of course.
Re: Waterpump Paint?
January 13, 2018, 16:01:36 »
http://www.v-strom.co.uk/smf/index.php?topic=21117.0
I reckon this is the one.
Fat Rat
Administrator
Bloke/Geezer/Fella
Bike: DL650A L6, K8 DL1000 & Tenere 700
Reply #2 on:
January 13, 2018, 16:26:10 »
I used Halfords Silver Wheel Paint.
http://www.v-strom.co.uk/smf/index.php?topic=23532.msg230537#msg230537
Have you considered going matt black?
Bikers Campsite in West Wales
Visit the
V-Strom.co.uk shop
today!
chris1200
Bike: 2008 V Strom 650.
Reply #3 on:
January 13, 2018, 18:28:00 »
Masked mine off and did it matt black. Doesn't look too bad at all.
Holmsey
Bike: DL650 L9
Reply #4 on:
January 13, 2018, 18:55:26 »
Have you thought of Raptor paint ???.
I saw it at a show I was at in April. ... Bloody good stuff .... Heat and chip resistant. ... I'm still considering doing my panels in the stuff.
Life on two wheels is better than 4 because the wife don't go on two wheels " I'M FREEEEEEEEEEEEEEEE "
RBLR 1000 - 2018 -2019
Armistice 1000 - 2018
Firestorm
Reply #5 on:
January 13, 2018, 23:23:19 »
Thanks for the replies Folk. I don't really want to go Matt Black - at least not yet. I think I'm going to try Autotek Steel Wheels as it'swell.... a little less silver! I'm going to paint the Chain Adjuster plates with it so it won't be a waste if it doesn't match. Will post the results as it seems to be very difficult paint to match.
Fat Rat
Administrator
Bloke/Geezer/Fella
Reply #6 on:
January 14, 2018, 00:05:29 »
If you really go for it and strip it down, paint the Clutch cover and Water Pump with the same paint.
Simples.
Visit the
V-Strom.co.uk shop
today!
endintears
Bike: KTM 1190 Adventure
Reply #7 on:
January 14, 2018, 12:09:42 »
Vauxhall Titanium Pearl.
Not an exact match but very close, just bought a rattle can (HYCOTE) and its put up with the heat OK, only used it on the pump mind, other cases might get hotter.
Rich:-)
Reply #8 on:
January 14, 2018, 17:08:42 »
Has anyone done a guide to stripping out both the clutch cover & water pump?
I'm tempted to do mine soon.
Fat Rat
Administrator
Bloke/Geezer/Fella
Reply #9 on:
January 14, 2018, 17:13:28 »
There's not much to it, drain oil and coolant, remove rear brake pedal and anything else in the way and then remove all the bolts.
Depending on whether it's a Vee or a Wee (it may be year dependant too), the Water Pump will either come straight off or the impeller will need to be removed from the inside of the Clutch cover (circlip).
Factor in replacing gaskets
Visit the
V-Strom.co.uk shop
today!
Rich:-)
Reply #10 on:
January 14, 2018, 19:30:36 »
The gaskets are what I was wondering about.... PITA to remove and not cheap to replace either (I suspect).
I may try to do them in-situ...
Fat Rat
Administrator
Bloke/Geezer/Fella
Reply #11 on:
January 14, 2018, 19:40:21 »
You may get away with the Water Pump gasket but replace the other with an OE part. I have done a few and pattern gaskets have always needed attention to stop small leaks.
Visit the
V-Strom.co.uk shop
today!
endintears
Reply #12 on:
January 15, 2018, 11:57:25 »
Repainted my pump cover in situ, took one mounting bolt out at a time prepped the area around it then bolt back in, just work around in succession then mask it all up for spraying.
Disturbs as little as possible but you can still do a decent job.
Waterpump Paint?
