Just a heads up, I have some bits for sale, all parts are from a 2013 650 glee but some parts may fit earlier vee's & wee's (please check for correct fitment)
Rough list is;
*Peg lowering kit (in black) £17
*Givi airflow (glee) £50
*Heed crash bars, no scrapes or damage, a little rust just starting in the corners of a couple of the welds. Bolts included £50
* Dark tint screen (powerbronze as I recall) £20
* Heated seat (aftermarket pad) these are utterly wonderful for anyone that rides all year! £40 plus exchange for your standard (and undamaged) seat and lh sidepanel (which has the lo/Hello/off switch fitted)
*Complete as new rear wheel in original unmarked black paint, complete with brake disc, abs ring, good sprocket & carrier. No tyre £90
*De-cat original exhaust system, a bit more open & free'er reving than stock, undamaged £100
*DL1000 cartridge forks fitted to glee lowers ( will fit wee) very slight light pitting towards the end of travel but oil tight. These are a full set of forks ready to fit and are a marked improvement over stock 650 forks. I can build onto the original 1000 lowers ready to fit onto the earlier model DL1000. £120
*Nitron shock, complete with hydraulic preload adjuster, adjustable comp/rebound damping, adjustable length and slightly heavier spring from stock @ 10kg/mm (stock is 8.5kg). It is slightly longer than stock but lowering links to keep stock height are supplied. Will fit glee, wee & vee, a marked improvement in handling over stock - particularly when pressing on £350
Alll prices are collection (either Leigh nr Manchester WN7 or Saltburn nr Middlesbrough TS12 as I'm flitting between the two at the moment or will post at cost
Pics to follow,
Phil
