Hi everyone, My bike is a 2009 DL650 ABS with 20,000 miles on it. Last week I went out for a ride and my ABS light came on, Clocks went off and bike cut out. Put battery on a optimate charger and red light came on wouldn't charge. Put a new battery on which was fully charged problem solved so I thought, Went back out did about 6 miles ABS light came on clocks went off and bike cut out. Looking at other previous posts on here I thought it's going to be the stator. These are the tests I've done so far.
Battery test: Fully charged 12.74 v started bike 11.97v left on tickover for 2 minutes 11.93v 3000 revs 11.88v engine off 12.45v
Stator test: Resistance on all 3 coils 0.4 0hms.Tested all three coils to ground none are going to ground. AC output at 5000 revs 76 v on all 3 coils.
R/R Diode test: + to + = 0 0 0 + to - = 564 564 564 - to - = 0 0 0 - to + = 564 564 564.
I disconnected the connector coming from the R/R to the battery to test the output from the R/R and it was showing 1.7 v on tickover.
I've checked the connectors and wires from the stator to the R/R and from the R/R to the battery for continuity and all are OK, Checked all the earth wires back to battery all OK, Checked earth strap from battery to engine OK, Checked all fuses and connectors to battery all OK. I don't have any add-ons running off my battery it's as stock.
Even though the the battery is new and the optimizer didn't pick anything up could the battery be the problem. Is there anything I have missed any advice would be much appreciated as I have now run out of options.
